rougeray Posted December 3, 2014 Posted December 3, 2014 I'm having an electrical problem and I need to check the grounding points on a 2nd generation bike. On the schematic for a 2nd gen. It shows two grounding points. The one that connects to the battery and then one that comes off the ground wire for all the other components that eventually ties into the grounding strap off the battery. When you open the link go to the battery (lower right and side) and you will see the two points. I want to know where the one to the left is. Thanks http://www.venturerider.org/wiring/99-09%20Yamaha%20Royal%20Star%20Venture%20Wiring%20Diagram%20Rev%20B.pdf
MikeWa Posted December 3, 2014 Posted December 3, 2014 I can't speak to the wiring diagram but there is at least one ground point behind the rear seat. Several wires are connected to a bolt going into the frame. Mike
rougeray Posted December 4, 2014 Author Posted December 4, 2014 I can't speak to the wiring diagram but there is at least one ground point behind the rear seat. Several wires are connected to a bolt going into the frame. Mike I have both seats off and I see no wires grounded to the frame. :confused24:
vzuden Posted December 4, 2014 Posted December 4, 2014 There is another on the right rear of the engine behind the horn
AlbertaClipper Posted December 4, 2014 Posted December 4, 2014 Rougeray, PM me your email address and I'll shoot you a couple of files that may help your search. I can't attach files to emails or threads on this forum. Mike
djh3 Posted December 4, 2014 Posted December 4, 2014 Looks to me it is showing the ground at the starter motor. The battery grounds at the motor behind the horn sort of. What sort of problem are you experiencing.
rougeray Posted December 4, 2014 Author Posted December 4, 2014 Looks to me it is showing the ground at the starter motor. The battery grounds at the motor behind the horn sort of. What sort of problem are you experiencing. See. http://www.venturerider.org/forum/showthread.php?91126-Charging-system-not-working
rougeray Posted December 4, 2014 Author Posted December 4, 2014 There is another on the right rear of the engine behind the horn That is the grounding point to the right of the battery. I'm looking for the one to the left.
rougeray Posted December 4, 2014 Author Posted December 4, 2014 There is another on the right rear of the engine behind the horn That would be the one to the right of the battery on the schematic. That is the main ground. If you look to the left of the battery you see a connector then the ground. I have found the connector but not the grounding point. After that grounding point a whole bunch of components hook to this wire. I would like to find this grounding point and clean it. If that does not help the next step is tracing the wire back to the connector looking for a bad connection. As you know the wiring harness are wrapped tightly and that would be removed and can never be duplicated. This is why I want to find this grounding point before it gets to that point. Chances are if no major repair work was done you would not know were this grounding point is. See http://www.venturerider.org/forum/showthread.php?91126-Charging-system-not-working
5 Buck Kanuck Posted December 5, 2014 Posted December 5, 2014 There is a ground wire on the luggage rack in between the rear seat & the CB but you have to remove the trunk to find it. Its a black flat wire . Hope that helps
Neil86 Posted December 5, 2014 Posted December 5, 2014 (edited) If you have the factory service manual, or have access to one online...go to SPECS> CABLE ROUTING pages....they show where the grounding points are located. Edited December 5, 2014 by Neil86
rougeray Posted December 6, 2014 Author Posted December 6, 2014 If you have the factory service manual, or have access to one online...go to SPECS> CABLE ROUTING pages....they show where the grounding points are located. Thanks, would never have thought to look there.
