Hello, I am new to this forum and thanks for welcoming me. I need some advice, my 87 Venture engine is somewhat stuck, I cannot roll the engine a complete revolution no can I get it into any lower gear than 3rd.
OK, first of all, welcome to the forum.
Can you give us a little history as in did this happen all at once?
How long have you had the bike?
Did it lock up while you were riding it?
Have you put it on the center stand and moved the rear wheel while trying to shift it?
Did you take the round cover off the engine on the left side and put a socket on the nut and try to move the crank?
If you put a socket and bar on the crank nut, when crank stops moving, is it sudden stop?
OK, here are a few things to think about and maybe we can help out a little better.
RandyA
Sounds initially like a transmission issue or shifter issue but might be an engine issue like a dropped valve or?? I would start with pulling the driveshaft out to eliminate the rear differential as the problem...
Thanks, I appreciate the help. I just purchased this bike from a member. I do not know any history except that the seller said he bought it with the problem. I can rotate the crankshaft almost one full rotation. The crank will get hard to move about half way but will continue with some force. When it stops it stops solid.
I still think the problem could be a drive train issue! Pull the rear tire off, remove the differential and pull out the driveshaft first and see if anything changes...
That would be my approach.
Hey Bobby, we agree for once!!:happy65:
I suspect you have a cylinder that got rusty from getting water in it. That is why I asked if it stopped suddenly, or would still move some. You may have to take the carbs and manifolds off so you can look down into the top of the valves. If there has been water in it, you will see a lot of crud on top of the valves.
RandyA
Ok, engine out of bike, bottom pan off, rod stuck in side of block through water jacket. I guess it was not a good buy, now need replacement engine.
That did not work either.
Yeah, it went for $237.50 with five bids and no I did not bid on it. I tend to be a last second bidder and will list my maximum bid that I am willing to pay. If it goes for more than that, then I don't feel like I lost out on anything.
Just curious, did you do more than the one bid? I started to call you earlier, but you did not have your phone number in your profile.
RandyA
Ok, bought an engine that must be overhauled. I understand that you can improve the performance by doing vmax cams, rejetting the carb, what are the facts and what do I need.
