89 vr:took the carbs off the 93,put them on the 89,run great,2200 mls,got home,took diap,from 89 carb,as 93 had holes,i had patched,run good for about 20 mls,bike starts & run like the excetator pump dose not work[i know that it dose not have an excelator pump]sea form-marvo mist oil,1200 mls to get it to run kinda right,have to have the chock,pulled out,outer wises,open the throttle a little,it will die,holding speed, it hasatates,just like no excelaror pump,pulled the air filter,spray a little gas in,works like it should,ijust can't beleave that all 4 carbs are,screewer up,so put the 89 carbs back on,runs like it should
what do you thank:confused24:
what winter,it's riding season here,the carbs can wait,vr runs ok just the gas milage is better with the 93 carbs,both bikes have new tires,and serviced,heck they are even clean,i'moff in the morn:cool10:
Glad you made it back home OK and also glad you was able to get your bike running better as well . Even when it was running bad you was getting real good gas mileage too. Hope for the better and ride safe tomorrow.
