Pulled the trigger yesterday on new to me 2009 RSV. Considering buying extended warranty and wondering what the consensus is on need.....are they a good deal ? I am generally not an extended warranty guy but have never owned a bike of this value. I know the RSV is bullet-proof but stuff happens.
I believe most will pipe up and say that these bike are fairly bulet proof.....if you'll do regular and required maintenance, I would concur. Had my 07 RSTD for 7 years. and have replaced tires, brake pads and point set in fuel pump, along with other maintenance while putting 38k miles on it. Suprisingly my battery is original. IMO if you are somewhat mechanically inclined and have some tools, then with all the tech support you can find on this site, as well as all the experienced riders, you should be able to handle most issues. Congrats on your never ride and welcome to the nuthouse.
I'd say that it depends on how cheap they will sell it. You may still have some factory warranty left depending on it's original selling date, its transferable.
Shock, fairing, fuel pump key switch and a coil are the moat common failures.
Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
If you bought it from a dealer have them check to see if there are any outstanding recalls on it. If not then I personally would say no to buying the extended warranty, unless like Jay said, they make you a very good deal on it. I'm on my 2nd Venture, a '99 I've had for 2 years now, prior to that I had an '04 Midnight for 5 years. The only issue with either was dry drive splines on the '04. Just keep the oil changed regularly and ride the heck out of it. Welcome to the site!:080402gudl_prv:
First off....welcome to the forum.
I have an '09 (candy red/raven). It was two months old and had 2500km on it when I bought it. I have almost 70,000km on it now, did a 10,000km trip West last year, and warranty until April 2015. The only issues I've had are :
- chrome trim piece below windscreen - original dealer that assembled the bike broke a couple tabs on it. Yamaha wouldn't warranty it. I used a tip from this site to fix them better than designed
- lower left cowling - one of the braces holding the "nut" portion broke. Possibly me over tightening it. Little ABS cement and been holding fine since. Easy fix.
- fuel pump - at about 60,000km. Warranty item
- rear shock "groans" but no oil leak - until it leaks oil I doubt Yamaha would cover the rear shock but I'll take it in to my dealer in the spring and find out. Groaning is probably the bushing
There are no recalls on the '09. Think the last recall was for the '07 because motor bolts weren't torqued properly.
Okay... so your new ride :
1) how many miles are on it? Too low might mean it wasn't ridden enough and some of the fluids might need changing. These engines will last 300,000 miles + with proper maintenance
2) do maintenance records come with it? Regular oil changes are the most important. Brake/clutch/coolant should be changed every couple years. Rear wheel gear oil too.
3) how mechanically minded are you? Most members on the site would recommend doing your own maintenance. I think because so few Ventures were sold per dealer, your local dealer might have limited experience working on them. My local dealer seems to use the same tech on Ventures - most experienced tech with Ventures. Too many horror stories of dealers screwing things up worse than what was wrong with them going in. Even with minor mechanical ability, there are enough resources on this site and members in North America that may be close enough to help you
4) as mentioned, the 5 year warranty starts from original purchase date. Check with a Yamaha dealer and they can tell you based on the VIN. Have them transfer the warranty to you. They might be able to provide you with a list of warranty work, and possibly service records for work done at a Yamaha dealer
Since you've bought the bike, make sure you check the rear shock for oil leaking. If there is oil residue on the bottom mount, you need a new shock. Check the site for recommendations. If it did leak previously the shop or previous owner may have cleaned it off. You'll know when you ride it if the bike seems to "pogo" or bottoms out easily.
Also, check the steering head to make sure it is tight enough. There is a tip in the read only section for a "quick" method for tightening the head. Too loose and in corners the front wheel will feel like it is floating thru the curve.
Check the plugs to see what kind of condition they are in. You'll have to remove the tank to get at the spark plugs, but may be worth a look to see how they are burning and if they should be replaced. TIP - remove the tank with low fuel, less awkward. Again, tips in the read only section.
Check the chrome trim below the windscreen. If there is a gap between the chrome and the windscreen, you should check the tabs. Don't buy a replacement ($250+) but use the tips to fix the tabs.
You'll find most people run 36-40psi in the front tire, 40-42psi in the rear. Check dates on tires. If they are 5 years old, you'll be replacing them soon. Dunlop E3's the most recommended. The OEM Bridgestones or 404's should be replaced if they are still on the bike.
Make sure you have the carbs sync'ed. Will ensure you get the best mileage.
For "required" purchases, get a lift adapter from Carbon One (Larry). If you do any work on the bike yourself, you'll need it. Plus...for winter storage, you can store the bike on the lift adapter (get it with the legs). A CarbTune to sync the carbs is good but there are probably members in your area that have one.
Last point.... post pics of your bikes and show off your new ride !!!!!
On my 02 I have replaced tires and brake pads and done routine maintenance. Just had to replace boots and get some carb work but that is the only problem in 12 years of riding. If you decide on the extended warranty make sure it covers parts and labour both. Otherwise it is not worth it. I favour Avon tires.
Hi MiRider,,, thanks again for helping to shore up the Michigan riders here on VR - lord knows we need some more representation - especially over here on the west coast!!
Anyway,, I am with you on the not really being an extented warranty kinda guy.. I have been had a couple times on those plans ( electronics related) - seems like the people who write the things are nice and really like to take the money up front but play a different tune when its time to pay out..
I am also with Raggie though, if it could be had for less than 4 or 5 hundred, at least added 2 years with unlimited miles,,, yea I might go for it.. but I highly doubt that is the case..
I know these bikes are not perfect, that stopped when the last 1st Gen was produced:stirthepot:.. But I also know they are very close to bullet proof, reguiring only maintenance to derive a couple hundred thou of miles...
Tell ya what I would do... I would put my extended warranty money into a "go to VR meet and greets/rallies and maintenance days" funds jar instead.. In the end your Extended Warranty monies will become an Extended Family Fund and the return on investment potential is far greater on the EFF (not necessarily in silver or gold - but, like Capt'n Sparrow said "not all treasure is silver or gold)... :cool10:
Welcome to VR and CONGRATS on the new bike!!
Puc
Hi
Welcome to the website. I have an 09 RSV went out of warranty sometime this year. Under warranty I replaced the following:
rectifier
rear schock
gas tank because of paint problems
front fender due to paint problems
the front rider seat due to tearing at the seams.
depends where u live we have a good group in Houston where we have maintenance days and we work on each others bikes.
let me know if u live in this area if u don't im sure you can find someone to help u with your maintenanance.
Hope this helps you,
WOW ! Thanks all for loads of good information. The bike has 40,000 miles on it and not a scratch so it has been well cared for. Rides like a dream and nice and tight so I'm not real concerned. To this point, I have done most of the maintenance on my bike, but previous ride was a v star 650 and this one is a little more complex. Based on the input I've rec'd. think I will pass on extended warranty and put the $800 quoted for a 3 yr. policy in the bank. Thanks again for the advice.
Hope you get a chance to ride it; being a late season purchase. I'm in MI too and just bought the RSV 2-1/2 weeks ago.
Anyone know how many Michiganians / Michiganders / Michiganites / Michiganese we have here?
One PUC too many:rotf::rotf::rotf::rotf::rotf::rotf::rotf::rotf::stirthepot::stirthepot::stirthepot::stirthepot:
For a mild mannered genius who just created free power for the world I get NO respect!!:stickinouttounge:
Hey Pucster,
Can you supply the part # and vendor for that part....I'm gonna buy a truck load and get rich....you indeed are a genius !
Picked up bike from dealer today and got some great news ! In spite of what I was originally told, I do have a year warranty left on original. :happy65: Bike was first purchased Dec. 2010 so I am good til Dec. 2015. Guess that seals deal on NO extended warranty for now.
BTW - 40 degrees this am, stayed very warm and bike rode like a dream. I am one happy camper ! Now to get some miles in before the snow falls........
Move south, we ride year 'round:thumbsup: unless you do something stupid and hurt yourself playing basketball so you have to cancel a nice scenic curvy road trip you had been planning for 3 weeks with your friends and wife who even took the day off to go with you. Now get out there and enjoy it as long as you can before that white crap starts falling on you.
