paysaw Posted October 22, 2014 Posted October 22, 2014 I just picked up an 86 Venture Royal.It will turn over and but not start.So far I checked the ignition fuse and it seems good,.According to the schematics it also powers the the cruise wich lights up when bike turned on.I am not hearing the fuel pump chatter i would normally hear. I will check for spark later.Is there a junction in the harness I should be looking for? THe PO said it ran last year. What are peoples thoughts.Battery is good and has lots of juice.
Condor Posted October 22, 2014 Posted October 22, 2014 I just picked up an 86 Venture Royal.It will turn over and but not start.So far I checked the ignition fuse and it seems good,.According to the schematics it also powers the the cruise wich lights up when bike turned on.I am not hearing the fuel pump chatter i would normally hear. I will check for spark later.Is there a junction in the harness I should be looking for? THe PO said it ran last year. What are peoples thoughts.Battery is good and has lots of juice. Pull a plug and see if you have spark, and check it for wetness. Not wet...no fuel. This is a good starting point....
Yammer Dan Posted October 22, 2014 Posted October 22, 2014 What Jack said. Good starting point. Get a plug out (no big deal) and you figure out which way to go.
Peder_y2k Posted October 23, 2014 Posted October 23, 2014 After checking the spark plugs, spray starting fluid into the airbox and see if it starts briefly. If it starts, and quits, the problem is the fuel system. -Pete, in Tacoma WA USA
stickhandle2 Posted October 23, 2014 Posted October 23, 2014 It is a companion bike Dave........LOL I get that Ray, my bikes needs a companion bike too. You can never have too many bikes. Mike
camos Posted October 23, 2014 Posted October 23, 2014 First thing to check is the battery connections. A good battery may not be able to put enough through a corroded connection. The terminals do not have to look corroded to block enough amperage to start the engine. Ditto for the terminals to the starter and the frame.
saddlebum Posted October 23, 2014 Posted October 23, 2014 What Jack said. Good starting point. Get a plug out (no big deal) and you figure out which way to go. What Yammer said.
paysaw Posted October 24, 2014 Author Posted October 24, 2014 Update: So, I got to thinking about things.I pulled the connector to the fuel pump, attached a multi meter to the connections and turn on the key. I got 11.2 volts for about 5 seconds.Hum, I said.The PO had pulled the air box off in desperation because of the no start condition. I did a light spray of ether on top of the carbs then hit the starter.The bike seemed interested.Then, I got ambitious and dribbled gas into all carbs.I then hit the starter button and instant start for a few seconds.I was just the fuel pump. Thanks for all your help guys.I have an extra pump lying around here somewhere and will swap it out and then post it running. I will be selling this bike if anyone is interested.It is not perfect but neither am I.Cheers, Ray
Neil86 Posted October 25, 2014 Posted October 25, 2014 Its normal to only have 5 seconds of power to pump, without engine rotation.Its a safety feature in case of a fuel leak. If the pump was clicking away for the 5 secs, just flip the kill switch off and back on to restart the 5 secs. Once carbs are filled then try the cranking. With the airbox is off, it will be hard to start cold....might want to reinstall.
paysaw Posted October 25, 2014 Author Posted October 25, 2014 Thanks Neil for the info.I was aware of the timing circuit of the pump.When I picked it up the PO was convinced the TCI was gone.I had a hunch it was some thing else. He was not a good trouble shooter I guess.I will put it all back together and then run it again.
Neil86 Posted October 25, 2014 Posted October 25, 2014 If the pump didn't click at all during the 5 secs, inspect the hoses for pump inlet and outlet. Sometimes an aftermarket hose thats too long is used creating a kink, and stalling the pump.
