My 2010 Venture came to me with Show Chrome heated grips. The grips are ok but they were missing the end weights on the handlebar. So before I go cutting the ends off my heated grips to reinstall the end weights I thought I would ask "has anyone done this before?" I have a set of weights minus the small plastic caps which I will get if this works. I also believe the handlebars are stock. So does anybody know if I am likely to run into any problems?
Thanks
Mike
Don't know how yours are set up but I ended up having to remove the threads for the end weights to Install my heated grips. They were inserts that I had to put inside the bar heat demons was the brand. I got some end weights for the Iso grips and installed them.
Edited by marcsmith
bad typing
