KISA Posted October 7, 2014 #1 Posted October 7, 2014 As work of Ignitech doesn't suit me, I want to repair the TCI 1986. With diodes everything is clear. Two questions: 1. Than to remove a rubber protective cover from a payment? 2. What will use condensers?
Prairiehammer Posted October 7, 2014 #2 Posted October 7, 2014 As work of Ignitech doesn't suit me, I want to repair the TCI 1986. With diodes everything is clear. Two questions: 1. Than to remove a rubber protective cover from a payment? Do you mean the conformal coating (конформное покрытие) on the circuit board? If so, go here for some help: http://www.empf.org/empfasis/oct03/3403rcc.htm 2. What will use condensers? I am not sure what you are asking. Are the condensers bad? Swollen? Broken?
KISA Posted October 8, 2014 Author #3 Posted October 8, 2014 I am occupied with slow preparation. Cases of breakages of condensers are known. Suddenly there is a ready decision.
