speak2you Posted October 1, 2014 #1 Posted October 1, 2014 I'ma Newbie, so be gentle please!! I have a 2002 Midnight Venture. I assume this is a 2nd Gen bike? I'm trying to learn the lingo/system here. I've looked at a couple threads on my issue: Non-working hazard lamps. Reading the threads are hard to jump in on. Here's what I know: All turn signals are working, so wiring to bulbs is fine as are the bulbs. I ordered a (used- so I get that may be bad too) replacement hazard module. Replacing the module that was on the bike fixed nothing. 1) Is there a way to test the module (right side of bike) to tell me if the module is bad? 2) What is next? Testing the switch inside the hand control? 3) When the ignition is off, the hazards do not work. Is this true? Or should they work ignition on/off? I've read this elsewhere on the forum, just confirming.
eusa1 Posted October 1, 2014 #2 Posted October 1, 2014 is there any reaction when turning the 4 way switch on? try turning on a left or rt signal at the same time as the 4 ways? no change would lead me towards the switch or the switch connection in wire harness
