I'm starting to feel like Yammer collecting parts each week. Always heard who ever had the most at the end wins. LOL
Well your garage is certainly big enough to hold a few more parts.
Since I don't have the room to store (or have) more, then I guess you win already.
You can stop now...ha
Did you figure out that old mower yet why it wont rev up?
I can only assume (after us talking about it) that the choke flap is either not free enough to fluctuate when under a load, or that the fuel line is kinked or partially clogged.
If I remember correctly, you mentioned it had a fuel pump.
The fuel line from fuel pump to gas tank could also have a kink in it or even a small hole/crack where the fuel pump is sucking air.
If I lived close enough, I would swing over to help you, but that's out..ha
Ill probably take the carb & fuel pump off this time to clean and soak them. Changing the fuel line wouldn't hurt. I'll let you know what I find.
