Hi folks,
My GPS (Garmin Nuvi 200w) has been loosing its power connection lately and I think I have isolated the problem to the in-line fuse holder. It is a glass type with a .75amp fast blow fuse in it. When I wiggle it power comes on and off. The fuse looks good but the holder is loose. I am looking to replace the holder with a waterproof blade type but the closest fuse size I can find is either .50amp or 1 amp. Will I hurt anything if I go with a 1amp fuse?
Thanks
:canada:
It may be the fuse holder, but my Nuvi had another problem that caused it to loose power, and then come back on. It happened much more frequently on rough roads. I also initially though it was my fuse holder, but after tightening it up, I still had the problem. Then I noticed that my low battery electrolyte alarm (1st. Gen) wasn't coming on, and the same fuse fed the resistor that I used to permantly turn the alarm off. If my fuse holder had a problem, the alarm would come on also. I wondered if something wasn't jaring in the power supply itself, causing it to drop out. My GPS power supply is in the bottom of the right fairing, so I decided to wrap it in spongy packing, and that cured my problem. It's been 2 years now, and it hasn't dropped out once. If you still have a problem after you replace your fuse holder, consider cushioning the power supply.
  XV1100SE said:
Thought the GPS called for a 2A fuse.
Manual calls for a 3A fast blow fuse for a Zumo 660
Thought that also, but the hard wire kit for mc from Garmin has that hard to find .75a one.
:canada:
Changed the fuse and holder this morning and put a 1a fuse in. Also found that my battery terminal screws where stripped and loose, so that could have been the start of a larger problem. :mad: I replaced them with longer ones and now all seems to be snug and tight. Thanks again for all the help.:thumbsup:
:canada:
Ok thanks, will keep that in mind if it acts up again.
:canada:
I had the same problem recently and it turned out to be the cord. I was using a coil cord and the pressure on the connection on the rear of the GPS was causing an intermittent power loss. Replaced with a "straight" cord; no problem since!!!! Good luck!!!!
  Quote
Somewhat similar experience. Took me a while to figure out that my problem was just at the plug into my gps.
