ridefree40 Posted March 18, 2008 #1 Posted March 18, 2008 anyone knkow the the recomended air pressure for the front shocks and the rear one?
Pilot Posted March 18, 2008 #2 Posted March 18, 2008 The owners manual says that the maximum air pressure is 7.1 PSI on the front and 57 PSI on the rear. Don't use an air compressor to adjust them you will blow the seals.
rod Posted March 18, 2008 #3 Posted March 18, 2008 I run 5 psi in the front and 40 psi in the rear. More on the rear if on a trip 2 up and loaded. Rod
