The owners manual says that the maximum air pressure is 7.1 PSI on the front and 57 PSI on the rear.
Don't use an air compressor to adjust them you will blow the seals.
I run 5 psi in the front and 40 psi in the rear. More on the rear if on a trip 2 up and loaded. Rod
