Gotta remove the fairings to get to the front screws. I imagine it could be done, but it's a PITA... Besides it's not that hard, and makes life so much easier...
loosen the clamp at the back of the air boxes to hose, then take 1 10 mm bolt out above and below air box and take the entire boxes to the bench to remove 6 screws from each
I use the long phillips screw driver for adjusting carbs, and loosen the clamp at back connecting to tube. then it's 2 10mm bolts as mentioned. one you can go pretty straight inot get, the other I have to use a universal on. There is more screws holding the box's together than there is to get them off.
