dacheedah Posted September 4, 2014 #26 Posted September 4, 2014 I thought if you owned a wing, you didn't need no stinkin locks:rotf:
yamagrl Posted September 4, 2014 #27 Posted September 4, 2014 When all else fails... Get a bigger hammer!
DougMoll Posted September 29, 2015 #28 Posted September 29, 2015 If you locked your key and remote keyless fob inside your trunk on a Honda Goldwing 1800, and you don’t have a spare key, here is a trick or a work around to help you out in this situation. This works like a charm but you will need two things. 1) -The allen wrench to take of the passenger grips off the seat so you can remove the seat. 2) - You will also need a 2ft long 14 / 16 gage wire for jumping the connection. Instructions: 1) remove seat 2) connect a wire to the "positive" on the battery terminal 3) under seat, find the GREY 14 pin connector - (on side without battery towards the back) 4) insert (just touch) the other end of the wire in the back of the connector to the "BLUE" wire 5) IT UNLOCKS note: Leave the GREY 14 pin connector CONNECTED - do not disconnect the connector as it needs to be connected to complete circuit. You should learn from this to ensure you carry or hide a spare key on your motorcycle just in case! Here is a photo of the GREY 14 PIN connector with instructions. This worked beautifully. Just had some trouble identifying the GREY 14 pin connector, but it worked beautifully. It won't happen again!~!!!!!
Venturous Posted September 29, 2015 #29 Posted September 29, 2015 I like being able to lock or unlock the trunk and all bags with one click. I wish they had included in that the helmet locks. It would be nice if they would unlock along with the trunk/bags.
YamahaParExcellence Posted April 14, 2018 #30 Posted April 14, 2018 And we learned this because??? "So you know how to steal something outta the locked trunk...! Oops!"
