91nwl Posted March 17, 2008 #1 Posted March 17, 2008 I lost one of mine. Anyone know where I can find a replacement?
Eck Posted March 17, 2008 #2 Posted March 17, 2008 I lost one of mine. Anyone know where I can find a replacement? Depends on what type of grip you have..... If you have the Kuryakyn grips with the end cap that is held on by (4) little allen head screws, then today is your day..
Condor Posted March 17, 2008 #3 Posted March 17, 2008 I lost one of mine. Anyone know where I can find a replacement? From your gallery pics it looks like you have the OEM foam grips, and I think I might have one floating around out in the garage. I'll check. OK I have one but I'll be damned if I can figure out how to get it off the grip, but I do see a phillips head at the bottom of the tube??? I suppose I'll need to find a long phillips to find out. It whole cap turns freely. You might have to remove the grip to get another one on. The cap I have isn't mint, but it is presentable. If I can get it off, it's yours if you want it....
91nwl Posted March 17, 2008 Author #4 Posted March 17, 2008 From your gallery pics it looks like you have the OEM foam grips, and I think I might have one floating around out in the garage. I'll check. OK I have one but I'll be damned if I can figure out how to get it off the grip, but I do see a phillips head at the bottom of the tube??? I suppose I'll need to find a long phillips to find out. It whole cap turns freely. You might have to remove the grip to get another one on. The cap I have isn't mint, but it is presentable. If I can get it off, it's yours if you want it.... Thanks I have hotgrips. I used the stock end caps from my 91 VR. They just pliugged into the hole in the end of the stock grips. I don't think there was a screw. I had em siliconed on. I guess I didn't use enough.
91nwl Posted April 2, 2008 Author #5 Posted April 2, 2008 I called Yamaha and the chrome grip caps are still availbale. Amazing. I guess they never clean out the drawers. $6.75 each.
