GMa and I took a shot ride yesterday. Took off from a stop sign and in second gear the red oil light blinked. By the time I got off the throttle it went off. Its and 06. Should I calle the dealer? ----Buzz
Don't think so. If you took off kinda of fast it could just be low oil level. I found that mine will come on if I am gettin on it from first and second pretty good if I don't have the oil level all the way up to the top mark.
If you take off fast enough, that oil light will come on even if it's not low. Check the oil level in the sight glass and if it's where it ought to be, then don't worry about it.
Common 'Problem' on the Vmaxxes. Mine lits up on almost every take off.
Just check the Level, if it's fine, you are fine. If it's annoying you, on the next Oil change, dismount the Sender Unit and mount it back in with 180 Degrees turned. Now the Oil gets into the Sensors Boring from behind instead of stock front Inlet. As the Oil goes back in the Pan on Acceleration, it will stop flickering.
