rbig1 Posted August 18, 2014 #1 Posted August 18, 2014 well I need a set for my 83 royal. tested connector on left side just like two not there no meter movement the other 33.9 there is only one 6 gang connector with one left blank.
dingy Posted August 18, 2014 #2 Posted August 18, 2014 (edited) well I need a set for my 83 royal. tested connector on left side just like two not there no meter movement the other 33.9 there is only one 6 gang connector with one left blank. On the six pin connector, there is a blank space, wire above that space is common to all 4 coils. It is black, but often difficult to see color due to somewhat dirty conditions in area where connector is situated. There is also another 6 pin connector in same area which is for gear indicator if your bike has a digital gear indicator. This on has all 6 pins used. I don't think the 83's had this, but it could have been modified in the last 31 years. With one meter lead connected to black wire, then check each of the other 4 wires. Reading should be between 93.5 ~ 126.5 ohms each. My personal opinion is it doesn't matter if reading is to high or low end of range as long as all 4 are consistent. Next attach one lead of meter to clean frame ground (or negative battery terminal) and check each of the 5 wires for any continuity to ground. Highest ohm setting on meter preferable if it is not an auto range style meter. Reading should be infinite (not 0 or near) on any wire to ground. This is starkly different than procedure for testing stator coils. But that is not your issue, so I won't muddy the waters with that. Just threw that out there since both components are in the same area and wires exit at same point. I do have a couple of sets of pickup coils if you are sure that is problem, but it is a job to replace them. Both left side motor covers need to be removed for access. Both will need new gaskets. Also look at contact mating surfaces on 6 pin connector for dirt, grease or corrosion. Also check connectors on TCI plugs for dirty or corroded connectors. 6 pin connector on TCI is one that pickup coils feed into. You can also check ohm readings at TCI on cable end of the 6 pin connector. Do not take resistance readings into the TCI itself. On the 6 pin TCI connector, all six are used. The Black with white tracer wire is not involved with pickup coils. Use black as common again. Gary Edited August 18, 2014 by dingy
rbig1 Posted August 18, 2014 Author #3 Posted August 18, 2014 thank you. I tested it the correct way and all is fine with it. so that leads me back to carbs. the other site had a nice tec article for rebuilding. I am worried cant get two drain screws loose no drive head left on them. will they survive when torn down. going to set down and memorize as much as I can
