May be missing the boat but seem to be reading most folks need to change back brake pads before the front. Most bikes are just the opposite. Have I misread, need more coffee, what gives? :detective:
On the RSV (probably the TD also) the rears go first. I guess partly because there are 2 up front to stop and the weight. What will help you on the rears getting a few more miles out of them is at about 5-6k swap the pads from one side to the other. I do it about everyother oil change so maybe 8K or so. Your milage may vary.
