I get an intermittent miss on cold idle with the choke on. Not constant but intermittent. Once the bike warms up it idles fine. Bike runs fine at speed.
I put on all new plug wires and caps (one was corroded with high resistance the rest were spec) and hoped it would clear up.
Is this more likely a carb, coil or other ignition issue?
Thanks
Edited by tz89
I should have noticed and paid more attention to the wandering idle speed. A good indicator of an air leak.
This morning I replaced the cracked vacuum port caps. I noticed improved cold idle and didn't notice any missing, but I had to get to work so haven't done any real testing.
Could it be that simple? :detective:
Done. It could use a sync now but until my brother sends back the digital carb sync I built (see write up) it will wait.
Thanks for the help. Best $12 ever. :dancefool:
