uncledj Posted August 9, 2014 Share #1 Posted August 9, 2014 I have a chance to pick this up pretty cheap. ($1K) and I think I'm gonna do it. 16K miles, he says it runs, but the carb needs work, as the needle valve sticks...??? It's being sold by the friend of a friend, and is about 3 hrs away, so I haven't see it in person yet. I came pretty close to buying a KLR650 last year, but hesitated and it was sold. BMW seems to get pretty good reviews. It's a 99 BMW F650 Anyone here have any opinions on this bike? Link to comment Share on other sites More sharing options...
tufftom4 Posted August 9, 2014 Share #2 Posted August 9, 2014 For the money I would snag it in a heartbeat even if it does need a little work. Link to comment Share on other sites More sharing options...
Yammer Dan Posted August 9, 2014 Share #3 Posted August 9, 2014 Good run around bike. Buy it and Sea-Foam it hard. Probally will cure. Link to comment Share on other sites More sharing options...
Bob Myers Posted August 9, 2014 Share #4 Posted August 9, 2014 While seafoam is a fantastic tool for what you spend it likely won't fix this. These bikes have a weird anomaly in the carb, as they age and wear the mixture gets richer and richer, to the point fuel just runs out,,,sure fire cure is to rebuild the carb. Watch for water pump failures, check the oil, not just level but content. Chocolate milk is a sure sign of a leaky water pump. For $1k, you could order a new carb from Daddy Beemer and still come out ahead Link to comment Share on other sites More sharing options...
bongobobny Posted August 9, 2014 Share #5 Posted August 9, 2014 Are you sure it's a Beemer and not a Harley? It looks like it pee'd on the floor... Link to comment Share on other sites More sharing options...
uncledj Posted August 9, 2014 Author Share #6 Posted August 9, 2014 Are you sure it's a Beemer and not a Harley? It looks like it pee'd on the floor... I noticed that too. Looks like it could be oil dripped from an over oiled chain. I dunno for sure. Link to comment Share on other sites More sharing options...
uncledj Posted September 20, 2014 Author Share #7 Posted September 20, 2014 That pic shows gas on the floor. I picked it up and put a new battery in it. It took me about a half hour to figure out that it'll do NOTHING with the kickstand down. Not even in neutral. Anyhoo, (with the kickstand up), it turned over for a few seconds and fired up. I could smell that the gas was old, but there wasn't much in it, so I put a gallon of fresh gas with some seafoam in it, and just like the seller said, it was dumping gas from the carbs. I turned the gas off and left it sit for a week (it was at my dads' house 3 hrs away). When I picked it up, it wasn't leaking anymore. I've had it sitting here with the gas on for a week now, and no leaks. I start it and run it up and down the street every day...leave the gas on....no leaks. I don't know what to make of it, but I ain't complainin' All in all it runs GREAT. starts easily, and everything works as it should. New chain and sprockets on it too. I must say that with the tires on it,....good tread, but they're street tires, ....it doesn't grab for poo on the grass , gravel or dirt. I'm considering putting a set of enduro tires on it. Overall, I'm very pleased with it, and think it'll serve my purpose as a shuttlecraft for the motorhome quite nicely. Link to comment Share on other sites More sharing options...
Yammer Dan Posted September 20, 2014 Share #8 Posted September 20, 2014 Another victory for Sea-Foam. Carb may need rebuilt later but any time you pick up something with fuel problems Sea-Foam is a great bet. Buy some Marvel Mystery Oil to keep it going. Link to comment Share on other sites More sharing options...
midnightventure Posted September 20, 2014 Share #9 Posted September 20, 2014 Looks like you got a bargain. People keep giving Harley a hard time about leaks and I have 2 high mileage Japanese bikes and they both leak a little. Link to comment Share on other sites More sharing options...
Monty Posted September 20, 2014 Share #10 Posted September 20, 2014 I would change the oil right away, with it flooding like that, you could have some gas in the crankcase. Link to comment Share on other sites More sharing options...
bongobobny Posted September 20, 2014 Share #11 Posted September 20, 2014 Ya done good!!! Link to comment Share on other sites More sharing options...
