Donvito Posted August 6, 2014 #1 Posted August 6, 2014 I was able to determine, with Dion's help, that the problem with my intercom is the microphones. They are about 20 years old and are J & M HS-134. The speakers work in both headsets. Performed some exploratory surgery on one of the microphones. I have attached pictures showing what I found. I don't know the terminology but I'm wondering how the u-shaped piece attaches to the round piece? Or if the u-shaped piece was a circle originally and I lost the remainder when I cut open the housing. Has anyone repaired or replaced these things and where do you get the parts? Any info is appreciated as I don't know much about how it works. Thanks.
etcswjoe Posted August 6, 2014 #2 Posted August 6, 2014 Try Sierra Electronics they may be able to get you a replacement boom. http://www.sierra-mc.com/products.asp?cat=89
videoarizona Posted August 6, 2014 #3 Posted August 6, 2014 I would contact them(J&M) directly. Be good to know what the retail cost for replacement would be. Then you could shop around. Probably find one on EBay... 1-800-358-0881 david
djh3 Posted August 6, 2014 #4 Posted August 6, 2014 I looked to be some sort of bonding agent when I looked at them the other day. but you couldn't really see on the mic part where it was attached. like existing solder or anything. From my own searches J&M and sierra and edsets look to be $60+ for a mic. for about $20 more you get all new stuff. I am messing around building a homemade headset and so far the mic has been my stumbling block. I have been busy on another project of lately here so thats been on the back burner.
Prairiehammer Posted August 6, 2014 #5 Posted August 6, 2014 Perhaps replace the J&M broken mike with an electret miniature? http://www.ebay.com/itm/3pcs-3-2mm-Long-Wire-Electret-Condenser-Microphone-Cartridge-Pick-up-6mm-x-3-5mm-/390888819474?pt=US_Pro_Audio_Microphones&hash=item5b02ca0b12
Donvito Posted August 6, 2014 Author #6 Posted August 6, 2014 I need two microphones and two lower wires. From Sierra, for J & M the prices are $70 for the microphone and $60 for the wires or $130 per headset. Looking at those numbers, probably better off buying new headsets. Considering IMC's for $85 but not sure of the quality compared to J & M. Anyone have an opinion.
