OK I have two of the choke plungers leaking. :crying: Only leaks when you open and close the choke. Should worry about this or should I change them out? :think: I have extras! :beer:
OK since no one has any advice I changed out the one that leaks the mos and that is OK. :stickpoke: Now the other one only leaks a little if it's on full choke so I'm not going to worry about it right now since I only need to use half choke to start the bike when I do use the choke. :whistling:
Seems like everybody choked up on answering you and were afraid to plunge into the thread with an answer.. :confused24:
Yep that's about it. I was thinking..Why??? can they be fixed? I would have changed them both if I had extras doing nothing.
I changed out the one that was really bad, now it is dry. The other one isn't bad enough to justify taking the carbs apart to do. Unless someone knows how to do it with out tearing them apart. :think:
