midnightrider1300 Posted August 1, 2014 #1 Posted August 1, 2014 who sells the wiring kit 2nd gen to change it over with isolator...I bought 1 a couple years ago but forgot WHO i bought it from.... it sure makes it easier...... HELPPPPPPPPP
utadventure Posted August 1, 2014 #2 Posted August 1, 2014 M61A1MECH - great plug and play connector!
XV1100SE Posted August 1, 2014 #3 Posted August 1, 2014 If you are installing a 5-to-4 converter/isolator...get a good powered one. I found that my bike brake light would flash if I turned on a signal. Installed a Reese powered converter and no more feedback to the bike
Black wing Posted August 1, 2014 #4 Posted August 1, 2014 If you are installing a 5-to-4 converter/isolator...get a good powered one. I found that my bike brake light would flash if I turned on a signal. Installed a Reese powered converter and no more feedback to the bike i had the exact same issue and also put in a reese 5-4 two days ago works great
Condor Posted August 1, 2014 #5 Posted August 1, 2014 i had the exact same issue and also put in a reese 5-4 two days ago works great How big is that Reese Iso, and what do they cost?? I put a powered Iso in my '99, that didn't take up a whole lotta room, but can't remember the brand??. I did pick up a new Rivco off eBay for the '07, but it seems much larger than I remember... I guess I could stop being lazy and go out and take a look...
