Dale124 Posted July 26, 2014 #1 Posted July 26, 2014 Sorry for the Rocky reference there, but I am so thrilled that I actually was able to install my passing lamps. I am not a mechanically inclined person, but have some technical skills from my technician background, and I thought that this install doesn't require a motorcycle mechanic to do, and when I was in buying these lamps and the mounting bracket, I asked the guy in the service dept. how long this would take them to install and how much it would be, he didn't seem to know! I was not thrilled with the prospect of paying them $110/hr without knowing how long this might take them, so yesterday I tackled it on my own. I did, however, chicken out on adding the relay, as I did not want to remove the gas tank to get the wiring to the battery. Maybe in the future I might attempt this. Anyway, this took me about 7 hours, which is much lionger than it should have, but I was being very careful not to cause any problems. It seems that when I don't know exactly what I am doing, if there is a way to do it wrong, I will find it. Anyway, I turned the boring looking front end into something much more attractive. Here is the final product. Dale. [ATTACH]85981[/ATTACH]
Venturous Posted July 26, 2014 #2 Posted July 26, 2014 Congrats. I do recommend you use the relay method if you ever get the nerve to tackle the gas tank. Removing the gas tank is really isn't that hard. Just make sure you have an old blanket or couple of towels to lay it on to prevent any dings.
Flyinfool Posted July 26, 2014 #3 Posted July 26, 2014 Nothing feels better than a job well done. But I would still look into adding the relay, even if you have to sneak the wire along some where until you get around to pulling the tank.
Bubber Posted July 26, 2014 #4 Posted July 26, 2014 Ya done good Dale124. Now see that wasn't so hard. Bubber
friesman Posted July 26, 2014 #5 Posted July 26, 2014 Looks great Dale , congrats on a job well done! now I just gotta tackle mine! Brian
EasyRider Posted July 26, 2014 #6 Posted July 26, 2014 something your FRIENDS here will never let you stop!! Always something new in "Safety Chrome" A term we use to convince our wives of the need to purchase in order to arrive home in one piece when riding. Hmmm when we first approach them we say it safe to ride a motorcycle AND economical then after purchase cagers can't see us and even cheap safety chrome requires :mo money: Great Job Safety Chroming!
djh3 Posted July 27, 2014 #9 Posted July 27, 2014 If you installed it per the yamaha instruction I bet you cut a scotch lock tapping power from the headlight for you 35w ea passing lights. Removing the tank is easy, especially if you are under 1\2 tank. Besides then you could install and ignition by pass relay to help save your switch. Dont get us wrong. You have tackled a tricky job. I remember the 1st time I. Took the fairing apart. Man was I scared. You have done a good job, but we are just trying to give you some advice to preclude problems don the road.
Dale124 Posted July 27, 2014 Author #11 Posted July 27, 2014 Thanks, all, for the kind words. I think I will eventually install the relay (I have It here for when I get brave). My kit did not come with a device to tap into the headlight power (scotch lock?), even though it was in the instructions, so I had to peel off some of the jacket of the high beam power wire, and soldered onto it. I had the most trouble getting the last step complete, which was installing the newly wired light bar onto the frame, as the fairing blocks the mounting holes. Oh well, it is now done and looks good with all that "safety chrome". Dale.
djh3 Posted July 27, 2014 #12 Posted July 27, 2014 OH yea running them wires can be a PIA. I was doing some work up front. I think lowering the forks in the trip tree. I got everything put back together and I was pretty proud as that was no easy job. Then a few days later I lost passinglighs, turn signal with blown fuse. Took a bit to find. but the way the wires were routed up in front they got pushed into the steering stops and pinched the wires. That my friend was a mess to fix.
Dale124 Posted July 27, 2014 Author #13 Posted July 27, 2014 djh3 said: OH yea running them wires can be a PIA. I was doing some work up front. I think lowering the forks in the trip tree. I got everything put back together and I was pretty proud as that was no easy job. Then a few days later I lost passinglighs, turn signal with blown fuse. Took a bit to find. but the way the wires were routed up in front they got pushed into the steering stops and pinched the wires. That my friend was a mess to fix. That does not sound like fun. I had heard one member was able to use a fish tape to get wiring under the tank to the other side, and I was thinking of trying that, but then thought that I'd like to see where the wires are going, in case of something like you described, or, resting on something that is somewhat sharp or heats up, etc. Oh well, it will do for now til I get brave. Having taken the fairing apart several times now, I am more confident to do more work on the bike. Now, if only I knew how to change my own oil, I'd be set Dale
Bert2006 Posted July 27, 2014 #14 Posted July 27, 2014 Removing the gas tank is real easy, actually easier than trying to fish wires through.Freebird has an excellent write-up on how its done here. If I can do it following these instructions, you can too. http://www.venturerider.org/forum/showthread.php?t=737
djadam Posted April 7, 2015 #15 Posted April 7, 2015 Has anyone on here with a 2nd gen RSV installed a switch for their passing lamps? I just got mine, I haven't installed them yet, but it came with an on/off switch. Should I install that or just wire it so its always on when the bike is on? I appreciate any and all help. Pictures of where some of you have put the switch would be great to give me some ideas. Thank you.
Bert2006 Posted April 7, 2015 #16 Posted April 7, 2015 Here is what I did: http://www.venturerider.org/forum/showthread.php?85214-Kuryakin-3-way-switch-install
