I think we'll need more info.
Do you have a passenger on two sides?? right and left.
What kind of passenger do you have that you need to have a rubber for?
OK OK,, all fun aside,,, maybe you could explain what you mean by rubber.
The foot rest has that rubber pad on it....well each foot rest on both sides have them....well three out of four of mine do...the right side rear foot rest doesn't anymore.
I have a 1999 royal star venture.
The floorboards on the 2nd gen have removable rubber pads. I believe you can order them through Yamaha. If I remember right Several Star bikes use the same floorboards, so you should have no problem finding them.
Welcome to the forum. We are glad to have you here. You will find a wealth of information on your Venture. Perhaps you might want to consider becoming a supporting member. It is well worth the $12.
Mike
