I removed the chrome covers on the front wheel that covers the two disk. Just prefer the looks of a traditional looking disk and continuing to remove gaudy chrome that I don't like. I noticed one side looks to be weighted on the inside of the cover. On a 200 mile ride I notice no difference in the way the front wheel feels. I do wonder about that weighted cover and which side it is suppose to be on. Could not find it showing as being different in my shop manual. Thoughts?
I'm interested in the answer to this question. Like you I like the traditional look and was planning on removing the covers when I put a new front tire on.
I assume you have a 2nd gen. I too removed the disc covers as I liked the look of the machined rotors. It did not make any difference in the way the tires wore or the way it handled. This was on a 2008 RSTD. As I remember the weighted cover goes on the throttle side of the bike what I would call the right side. I do not know why it was weighted and I have never heard if anybody came up with a reason.
Sam, make sure you have a tool for removing the bolts holding the covers and disk in place. They are not common hex head and they are tight. I put back on using blue lock tight.
  • 1 month later...
  • 1 year later...
I know this is an old post, but has anyone figured out why one side has weights and not the other side. :confused24: I am thinking of removing mine.
As it's on the throttle side it might have something to do with compensating for the rotational forces of the drive shaft on the clutch side of the bike.
I removed the covers when I was still running the stock front wheel and did not notice anything odd with the way the bike handled or tracked. I have since switched to the 18" wheel of a Stratoliner that came with floating rotors and a smaller "insert" weight rather than the disk/cover. I did install the weight on the 18" but yet again did not notice anything significantly different.
One of these good old threads:
Yeah, that could be, but I don't know and Haven't heard from anyone who actually does. I took mine off years ago, and like everyone else who did, noticed no difference.
Here is a pic for those of you who want to know what those gorgeous machined discs look like:
  • 4 months later...
My weight was mounted on the left. but the tire had been changed before my recent purchase of the bike (2005 date code, yeah I know, but no cracks, may just run it off.) I see no difference side to side on the wheel? IE is there a left or right side to the wheel? I did mark it, but who knows if the last guy did..... I'm pretty sure the chrome is staying off on mine. Just stripped the flaking clear coat from rim and fork legs.
I like the looks of the covers removed, Had no idea that is what it would look like.
One thought, if the cover was weighted for balance, and the tire was balanced on the rim with the covers, removing them may throw off the weight.
One way to eliminate this is use of Balance Beads in the tire instead of traditional balancing. It is all that I use in mine, I got 22,500K miles out of my last front tire. The Balance Beads wont care if the covers are there or not,..
It's back together naked now. It appears the PO had the wheel on backward but now I need to check and see if the tire is on backward. :bang head: I had the rotors off, is it just my bike or is one rotor on "backwards" on all of them?
Note' my rotor bolts were a rusty mess. I ordered some stainless button head replacements (bout a buck a throw at Fastenal) but didn't want to put those old ones back on, used allenheads and washers til the right bolts come in. There isn't room for those taller heads to clear the fork tubes with the washers under them. No washers and they just cleared the tubes on mine.
I have been wondering for sometime what the weight is for, it is a dampener and it goes on the right side I happened on it looking threw my service manual
Orlin
I like the look without the covers. I may do that next time if I can find some Chrome Rotors. Anyone have an idea where I can locate a set? I had my front wheel chromed and think it would look better with the matching rotors.
Stratoliner S models came with chrome floating rotors, I did a full 18" wheel & rotor swap a few years back on my Venture.
I really like the looks of that wheel on our bike and I've found a few on the market but none that I've found come with the rotors or those covers. Add the price of the rotors and covers and they get expensive real fast. Still keeping my eyes open for a fair deal.
I stumbled on a hell-of-a-deal when I found the wheel, rotors & cover with blown out bearings on eBay in late fall of '14. I was due for a new front tire anyways. Lets just say (doing my own labor) it cost me less than most people pay a shop for a tire & mount.
  BratmanXj said:
`18" stratoliner wheel
What tire do you have on there?
Was it plug a play or was there dome "fiddling"
Any comments on handling before and after?
Will the existing rotors bolt on that wheel?
Orlin
Thanks for solving this age old mystery on here.
