Carbon_One Posted July 13, 2014 #1 Posted July 13, 2014 Today I finished my tach install. Here's the link to the one I used -- http://www.ebay.com/itm/281251433529?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 There's no name on it so can't say for sure who makes it but it looks and functions exactly like the Drag Specilities tach I had on my 05 trike. I used a Kuryakyn "P" clamp to mount it to the handle bar rather than the one provided. I did that the get the gauge in the spot where I wanted it, as well as the angle needed for viewing better. Wiring it was very simple. The four wires, red power, yellow - lighting, black - ground, and green negative post of the #4 cylinder coil (white wire). The light in the tach was a nice shade of blue. Tach accuracy was good with no bouncing needle. http://i.ebayimg.com/00/s/NjU1WDYwMA==/z/DYcAAMXQEgpTEQwu/$_1.JPGhttp://i.ebayimg.com/00/s/NTM4WDYwMA==/z/Uu8AAOxy4fVTEQwy/$_1.JPG
WildBill1 Posted July 14, 2014 #4 Posted July 14, 2014 A lot like the tach I install, don't you want some gages to go with it.[ATTACH]85663[/ATTACH]
djh3 Posted July 14, 2014 #5 Posted July 14, 2014 This one a fellow was installing and I think had to hook 2 leads to 2 different coils or something to get the RPM to read right. It looks almost like and autometer.
djh3 Posted July 14, 2014 #6 Posted July 14, 2014 The cart button is on only your computer man. I didnt push it. Your not alone though it causes me troubles also. I read stuff and then wonder about fixing or modifying mine. Same with adding some of the parts. But good thing I'm not a chrome guy I guess. I dont like polishing the stuff.
Wizard765 Posted July 14, 2014 #7 Posted July 14, 2014 My MM came with a Baron's Tach mounted on top of the brake master.. looks great and works great except at idle. At idle the needle bounces and is pretty much useless but once off idle it's rock solid.. sounds like yours Larry with the blue backlight etc.. just says Barons on it.. I wonder if there is something I can do about the bouncing needle at idle?
Carbon_One Posted July 14, 2014 Author #8 Posted July 14, 2014 A lot like the tach I install, don't you want some gages to go with it.[ATTACH]85663[/ATTACH] I thought about the set up you have but decided all I really needed (wanted) was a tach & voltmeter. I already had the voltmeter that I had on the previous trike so used it again.. Between these two gauges I know almost all there is needed to know what's going on with the engine and electrical system. The gauge pods do look awesome thou. Larry
Carbon_One Posted July 14, 2014 Author #9 Posted July 14, 2014 My MM came with a Baron's Tach mounted on top of the brake master.. looks great and works great except at idle. At idle the needle bounces and is pretty much useless but once off idle it's rock solid.. sounds like yours Larry with the blue backlight etc.. just says Barons on it.. I wonder if there is something I can do about the bouncing needle at idle? I had a Baron's tach like yours given to me. Didn't use it due to where my GPS is mounted and wouldn't of been able to see the tach mounted on the reservoir. As to the bouncing needle I've heard others commenting on that too and as far as I know one just deals with it. Larry
eusa1 Posted July 14, 2014 #10 Posted July 14, 2014 I like the volt meter you have in the handlebar clamp! where did that come from Larry?
videoarizona Posted July 14, 2014 #11 Posted July 14, 2014 I have a Baron's on my 950T. It bounces like crazy at idle and slowly gets better at higher RPMS. I've never been able to find a cure. Baron's says it shouldn't do it. I was thinking it was my installation since I had to take two leads from the 2 cylinders to get an accurate reading. Guess not...cheap tach most likely. No dampening...
Condor Posted July 14, 2014 #12 Posted July 14, 2014 I like the volt meter you have in the handlebar clamp! where did that come from Larry?
Carbon_One Posted July 15, 2014 Author #13 Posted July 15, 2014 (edited) On the tach seller, I never even looked at the their e-bay rating. It was a reasonable price, they shipped it in a timely matter, and works great so no complaints from my end of the transaction. For the voltmeter gauge a couple others have asked where I got it so here's the following info on that: http://www.amazon.com/dp/B0041QJQNQ/?tag=googhydr-20&hvadid=53463800489&hvpos=1t2&hvexid=&hvnetw=s&hvrand=11675153993203974341&hvpone=&hvptwo=&hvqmt=e&hvdev=c&ref=pd_sl_1q412ul70y_e A search on digital voltmeters on the web and e-bay show a few other choices but this one looks great and seems to be water proof as it's been on the bike for a while now. The handle bar clamp I made out of some stainless sheet metal. I added a couple steel spacers under it that fits into the recessed cap holes. That allows the plate to lay flat. Larry Edited July 15, 2014 by Carbon_One
Carbon_One Posted July 15, 2014 Author #14 Posted July 15, 2014 For free shipping I'm having it sent to BongoBob's... will post when it arrives. What ya getting ? tach or meter? Either way you'll be satisfied. Larry
Carbon_One Posted July 15, 2014 Author #15 Posted July 15, 2014 For free shipping I'm having it sent to BongoBob's... will post when it arrives. Larry PM sent
Dano Posted August 12, 2014 #16 Posted August 12, 2014 A lot like the tach I install, don't you want some gages to go with it.[ATTACH]85663[/ATTACH] I have been thinking about wanting..errr...NEEDING a set of those instead of the tape storage device. Still got them?
Condor Posted August 12, 2014 #17 Posted August 12, 2014 I have been thinking about wanting..errr...NEEDING a set of those instead of the tape storage device. Still got them? Ponch was the one that developed that cluster Dan. Sure do miss him....
Dano Posted August 13, 2014 #18 Posted August 13, 2014 Ponch was the one that developed that cluster Dan. Sure do miss him.... Sure wish someone would duplicate, I'm not THAT advanced yet..... Thanks for the reminder Condor, I tend to forget some of these things...
Condor Posted August 13, 2014 #19 Posted August 13, 2014 Sure wish someone would duplicate, I'm not THAT advanced yet..... Thanks for the reminder Condor, I tend to forget some of these things... There were a couple of members who made their own. I think it would be right up your alley, being electrical and all.... I think that if anyone contacted Ponch he'd be willing to pass on some pointers?? If I remember the biggest problem was finding the right sized gauges....
gibvel Posted August 14, 2014 #20 Posted August 14, 2014 Larry, What model "P" clamp did you use and did you have to do any other mods or add-ons to get the tach to sit the way it is?
Carbon_One Posted August 14, 2014 Author #21 Posted August 14, 2014 Larry, What model "P" clamp did you use and did you have to do any other mods or add-ons to get the tach to sit the way it is? I used a Kuryakyn 1" "P" clamp. As for the bracket I didn't use the one that came with the gauge but made my own out of a piece of 3/16" thick x 3/4" wide and about 3" long stainless steel. I bent a 90*angle on one end that positions the P clamp and then put a small twist in the main part to get the angle I wanted. I'll take a pic and post it here later today. Larry
gibvel Posted August 14, 2014 #22 Posted August 14, 2014 I used a Kuryakyn 1" "P" clamp. As for the bracket I didn't use the one that came with the gauge but made my own out of a piece of 3/16" thick x 3/4" wide and about 3" long stainless steel. I bent a 90*angle on one end that positions the P clamp and then put a small twist in the main part to get the angle I wanted. I'll take a pic and post it here later today. Larry Thanks!
Carbon_One Posted August 15, 2014 Author #23 Posted August 15, 2014 Got busy and forgotten the pics but here they are. Better late than never . LOL
Carbon_One Posted September 5, 2014 Author #24 Posted September 5, 2014 Never had any problems in rain. Maybe some sealer would help. Larry
Snarley Bill Posted September 5, 2014 #25 Posted September 5, 2014 hey larry, i think you need some one to test this new equipment. give me a call and i will break it in for you. can't wait to see it in real.
