Hello folks, I can't find the float height in the archives here. I am pretty sure I have seen the information on here in the past. I need to know where to measure from and the height. I think the height is 25mm but would like to confirm. Thanks.:fingers-crossed-emo
what ever you read about 25mm is wrong. To do correctly you must view the FUEL level, because floats vary with age. MUST HAVE PERFECTLY LEVEL CARB AND USE PROCEDURE IN OEM MANUAL. FYI- seperate then to two banks
