rbig1 Posted July 5, 2014 #1 Posted July 5, 2014 wife and I rode down to see the Mississippi flood waters. when we got there heat gauge was almost in white turned off bike she was boiling water. turned switch back on no fan. we stayed there for about 15min then took long way home so I could run faster ie air flow. I know where the sensor wire is. cant remember is there a relay or just a fuse. the little bands that held relays on are long gone. any one know wire colors blue to sensor----- if I remember correct all stuff wore off relays no numbers. going to work on tomorrow afternoon. I cant hear fan run when bike on. what ya say.
Yammer Dan Posted July 5, 2014 #2 Posted July 5, 2014 Check the wires coming off the sensor. might need tightened up.
rbig1 Posted July 7, 2014 Author #3 Posted July 7, 2014 well I think thermostat is sticking. added override switch to temp sensor. never made a big difference cools off all at once like stat opens. these bikes air lock in radiator. coolant is full oil full stat is only 2month old. rebuilt waterpump replaced most hoses.
