MidlifeVenture Posted July 2, 2014 Posted July 2, 2014 Picked up a suspension pump today and found I had 7 lbs in one and 0 lbs in the other front shock. I balanced them @7 I will monitor to make sure it holds. I wonder how big of a difference this is going to make. May have to brave the heat and ride to work tomorrow.
Beau-Kat Posted July 2, 2014 Posted July 2, 2014 Which pump did you get and how much was it? I need one for myself.
MidlifeVenture Posted July 2, 2014 Author Posted July 2, 2014 I've put it off so I just bit the bullet and stopped at HD dealer and bought it because I knew they stocked it. It was 54 and change with tax but I rode for the first time since returning from vacation in Ireland and something did not feel right hopefully this helps.
katoomer Posted July 2, 2014 Posted July 2, 2014 I'll give you the info on the one I have. The prior owner spliced my suspension air lines and purchased this pump which seems to be of good quality. It has a price written on the box of $51.95 It is Progressive Suspension brand. They have several air pressure ranges. This one is the GP3-60 which is from 0 to 60 PSI range. It has a short flexible air line, a no loss air connector, and claimed 3% accuracy. It has a air bleeder button. Aluminum body. See website for possibly more info.
Beau-Kat Posted July 2, 2014 Posted July 2, 2014 I'll give you the info on the one I have. The prior owner spliced my suspension air lines and purchased this pump which seems to be of good quality. It has a price written on the box of $51.95 It is Progressive Suspension brand. They have several air pressure ranges. This one is the GP3-60 which is from 0 to 60 PSI range. It has a short flexible air line, a no loss air connector, and claimed 3% accuracy. It has a air bleeder button. Aluminum body. See website for possibly more info. Sounds good. I know that one. The no loss air connector is really a plus for these low pressure applications. I can use it on the RSV and the VMax. Sadly, I seem to remember this same one offered a few years back for around $37. I thought it was too expensive at the time. Kicking myself for missing the boat on that deal. Thanks.
rougeray Posted July 2, 2014 Posted July 2, 2014 Amazon has a pump for $36 and change. Free shipping. Bagger Werx 07-012 Motorcycle Air Shock Hand Pump by Bagger Werx Link: http://amzn.com/B004Y18GKM
RedRider Posted July 2, 2014 Posted July 2, 2014 It is really close to the same price to purchase the HD branded Progressive pump and the Progressive branded one. Most HD dealers carry it in stock. Just stop by and pick one up from them. It will work on both the front forks and the rear shock. Good, solid, zero let-off pump that has survives thousands of miles in my tool bag stuffed in the right saddle bag. RR
ACE50 Posted July 2, 2014 Posted July 2, 2014 Seeing as I never adjust the pressure while I'm out riding, I just lower the pressure on my compressor regulator to a couple pounds over what I want to put in and pump them up.
Nemo Posted July 2, 2014 Posted July 2, 2014 A good post, guys. And Ray, I used your suggestion about the Bagger Werx and just ordered one. Owen.
RedRider Posted July 2, 2014 Posted July 2, 2014 Seeing as I never adjust the pressure while I'm out riding, I just lower the pressure on my compressor regulator to a couple pounds over what I want to put in and pump them up. Problem is two fold. It doesn't take much to blow out the fork seals and the typical regulator is not very accurate at low pressures. Secondly, there is so little air that goes into the forks, confirming the pressure with a gauge will change the pressure dramatically. The zero let-off is important. However, if this procedure works for you, all is good. RR
ACE50 Posted July 2, 2014 Posted July 2, 2014 Problem is two fold. It doesn't take much to blow out the fork seals and the typical regulator is not very accurate at low pressures. Secondly, there is so little air that goes into the forks, confirming the pressure with a gauge will change the pressure dramatically. The zero let-off is important. However, if this procedure works for you, all is good. RR When you set it down low, it goes in slow. Plenty of time to check it. Just like your tires. Do you leave the air chuck on your tires for 5 minutes at a time?...........NO! Not a problem, if it is, go buy yourself a $40 pump.
speakerfritz Posted July 2, 2014 Posted July 2, 2014 Amazon has a pump for $36 and change. Free shipping. Bagger Werx 07-012 Motorcycle Air Shock Hand Pump by Bagger Werx Link: http://amzn.com/B004Y18GKM yes..I have that one..works great and fits in my roll up tool bag
Beau-Kat Posted July 2, 2014 Posted July 2, 2014 Amazon has a pump for $36 and change. Free shipping. Bagger Werx 07-012 Motorcycle Air Shock Hand Pump by Bagger Werx Link: http://amzn.com/B004Y18GKM Thanks for the info. Just ordered a Progressive one from Amazon for $35 and change with free shipping. I like the zero loss feature. I used to have a low pressure pump (zero to about ten psi) that came with my 1996 Suzuki Quadrunner four wheeler. Of course, it was not as functional, nor made as well, as these Progressive ones. And I can't find that old pump in my shop anymore.
djh3 Posted July 3, 2014 Posted July 3, 2014 SO if this pump works 0-60 psi its fine for the rear also to me. As the max on the rear is only 57 PSI
