mralex714 Posted June 27, 2014 Posted June 27, 2014 What's the trick to removing the switch? Mine isn't working, first it was stuck and now nothing. Tried to adjust it and nothing. Hand brake switch works.
Venturous Randy Posted June 27, 2014 Posted June 27, 2014 (edited) There should be a small hole under where the switch goes in and if you stick something into the hole, there is a little catch tab. If you push it in, the switch will pull out. RandyA Oops, I was thinking front brake. Edited June 27, 2014 by Venturous Randy brain fart
Prairiehammer Posted June 27, 2014 Posted June 27, 2014 What's the trick to removing the switch? Mine isn't working, first it was stuck and now nothing. Tried to adjust it and nothing. Hand brake switch works. The plastic adjusting nut is captured in the mounting bracket by tangs. Using needle nose pliers, squeeze the tangs to release the switch from the bracket. http://i.ebayimg.com/00/s/NDgwWDY0MA==/z/yFUAAOxy4kpRAdbm/$%28KGrHqV,%21oEFCyPWfZ7MBR%21dbmckww%7E%7E60_12.JPGhttp://pinwall2.pinwallcycle.com/ebay/bike5751/844.jpg
