[ENGINE MAINTENANCE
TAPPET ADJUSTMENT
ENGINE MAINTENANCE
CARBURETOR ADJUSTMENT
CHASSIS MAINTENANCE;
BRAKES
FORK OIL CHANGE
STEERING HEAD ADJUSTMENT
ANTI-DIVE UNIT (XVZ12)
CHAIN LUBRICATION
FINAL INSPECTION
ENGINE REMOVAL
ENGINE DISASSEMBLY
CYLINDERHEAD RECONDITIONING
0:40' CYLINDERHEAD RECONDITIONING
1:00' CYLINDER BORING AND PISTON FITTING
1:06'46" OIL PUMP INSPECTION
1:08' WATER PUMP RECONDITIONING
ENGINE ASSEMBLY; CLUTCH; MOUNTING THE ENGINE.
CARBURATION
ELECTRICAL SYSTEMS;
1:41:50' INTRODUCTION
1:45:50' BATTERY
1:46:15" SPARKPLUG CAP
1:47:00 RESISTANCE CHECKS
1:49:50" CONTROL UNIT
ELECTRICAL SYSTEMS;
CHARGING SYSTEM;
1:50::00" INTRODUCTION
1:52:08" BATTERY CHECK
1:53:13" STATOR COIL CHECK
1:54:13" RECTIFIER CHECK
1:54:20" VOLTAGE REGULATOR CHECK
1:55:40" NEW ROTOR SECURING BOLT (XVZ12 MODELS)
COOLING SYSTEM;
1:56:18" FAN MOTOR CIRCUIT
1:59:35" TEMPERATURE GAUGE UNIT https://www.youtube.com/watch?v=LdF7bMiP01Q
ORK REBUILDING;
REMOVAL AND INSTALLATION https://www.youtube.com/watch?v=JPqpEn1-sdA
Edited by hell yea
Yes there is and can be found on Ebay. There is a carb video and a motor video by the same person. It is for VMax but is applicable to venture as well, just different jet sizes. Very detailed. Member Dingy knows the individual and may be a source for the video...
