Where the big wires connect to the battery and the starter. Manual says to connect power to the top left (as your looking at mounted relay) and ground to the top right. then it energizes the relay. When first energized (closed) its reads OK. But as you leave it connected the OHM start to climb. I have not checked my functioning RSV yet. The relay also gets pretty warm as it stays engaged.
  • 3 months later...
GRRRRR Its BACK. Got an e-mail from Retiredgolfer and he said it's back to old tricks again. So this is what maybe 3 months. I never did get a repeat no start once I had it here at the house and started OHM wires, and clean connections.
If I understand right, the side stand switch makes no difference as long as you are in neutral. And of course thats what is being indicated, so if green light on dash should be good. Kind of points to the SCC thingy ma-jig.
For intermittent electrical problems I often wire up some LEDs to various points in the suspected circuit. Depending on what the circuit is supposed to be doing, some LEDs will always be on some will always be off. Group all of the on's together and group all of the offs together, this way it is real easy for the eye to pick up even a flicker.
With the LEDs it is easy to see in real time exactly where the problem is.
There must be a problem with the 07's. My friend has an 07 and I posted about his problem. Bike wouldn't start, dealer put new selenoid on, then radio wouldn't work. Dealer replaced radio, $1,400. Bike worked fine for a few days and now it won't start unless you disconnect the radio. Dealer has had bike for 2 weeks. The heat light and temp light come on when it won't start.
Now I really afraid to say this... karma and all... but my '07 runs fine....
I think you need to take a silver stake and....... :whistling:
So now it won't start even with the radio unplugged or they are trying to figure out how the radio is preventing starting.
Bike has been at dealer for over two weeks. Service manager is going to send the new radio back to clarion for them to check it out. They don't know why bike won't start with radio connected.
