alvald83 Posted June 17, 2014 #1 Posted June 17, 2014 (edited) I just picked up an 83 dash off ebay (mine is an 83), just because I don't like how sun worn my dash is (I couldn't pass up a good deal). After installing it, I see that both signal arrows are staying on. Because my battery is dead, I cant see if they go out after it starts. Is this normal? Since I am charging my battery I cant check my original cluster. Edited June 17, 2014 by alvald83
bongobobny Posted June 17, 2014 #2 Posted June 17, 2014 By any chance is your 4 way flashers on? Is the connector for the 4 way flashers still connected? If it isn't connected it will knock out the turn signals...
alvald83 Posted June 17, 2014 Author #3 Posted June 17, 2014 update: It seems as though my 2 signals are lit like my neutral light should be and my neutral light flashes when I put my flashers on. Strange!
dingy Posted June 18, 2014 #4 Posted June 18, 2014 update: It seems as though my 2 signals are lit like my neutral light should be and my neutral light flashes when I put my flashers on. Strange! Try changing the center computer module with your old one, may cure problem. PIA to take back out, but it is a possible fix. Gary
KIC Posted June 18, 2014 #5 Posted June 18, 2014 How about the bulbs in the back..did the PO switch the bulbs around in the back of the unit ?
dna9656 Posted June 21, 2014 #6 Posted June 21, 2014 I think the bulbs were moved to the wrong holes. With the "meter" (dash) out but still connected electrically try turning on a blinker, move the blinking bulb to the proper hole(s).
