wolfrider Posted June 17, 2014 #1 Posted June 17, 2014 Saw this a long time ago. Haven't see it in a long time. A refresher on it. Yamaha dealers often will often tell you they know nothing about the whine. Here's Yamaha's Service Bulletin info on it. Motorcycle Technical Service Bulletins 2002 yamaha xvz13 Back to Technical Service Bulletins | Start Over Technical Service Bulletin Details Bulletin Number: M2002013 Bulletin Date: 6/14/2002 Year: 2002 Make: YAMAHA Model: XVZ13 Replacement Service Bulletin Number: Internal Sequence Number: 638087 Component Affected: 061100 ENGINE AND ENGINE COOLING:ENGINE:GASOLINE Date Added to File: 12/10/2002 Summary: SUBJECT REGARDING ENING WHINE FROM CLUTCH AREA. *TT
Bert2006 Posted June 17, 2014 #3 Posted June 17, 2014 :sign yeah that: Is there more info on how to adress the issue in the bulletin?????
