stanG Posted June 10, 2014 #1 Posted June 10, 2014 I got tired of the high beam indicator blinding me so I came up with this quick fix. A piece of plastic cut to the size of the blue lens with a small hole drilled in the center. I affixed it with a little silicone so if I need to remove it there is no residue. Much better and I can see it perfectly fine in the daylight too. http://img.tapatalk.com/d/14/06/10/qazyquny.jpg
djh3 Posted June 10, 2014 #2 Posted June 10, 2014 That confounded blue high beam light has been a !@$!@ of mine for years. When I was in the USAF and we would drive to Fla from OK it was usually me at night. I usually have the dash lights low to reduce eye strain and if you are running the brights that blue light bothers me bad. I would use black electrical tape on the dash of the car.
Flyinfool Posted June 10, 2014 #3 Posted June 10, 2014 When I converted my dash to LED I used a lower power Blue LED for the High beam indicator. Just right
