Does the 2nd gen RSV have a cb with a ground plane or not? Or do i need to worry about if i am not replacing any cables?
I want to replace my antennas with Firestik Firefly's 3ft'ers. I intend to also switch out the folding mounts as I was told that the originals would not be standard mounts that work with the Firefly's. Would be using the same cb antenna for am\fm side too.
:canada:
Yes the frame is the ground plane and you will need a duplexer to feed the two radios into one antenna.
BOO
:canada:
Guest tx2sturgis
If I understand your question correctly, you will be using one 3 ft Firestick for the CB and another 3ft Firestick for the AM/FM?
In that case you will not need a splitter, and assuming you are able to tune the antenna for lowest SWR, it should work ok for CB comms of a mile or less. Your AM/FM range might be seriously diminished as well.
I prefer the Francis CB antennas...they are made better and are not as thick and heavy. And they just look SO much better on a bike. You can find these at the larger truckstops or online:
http://francisantennaonline.com/francis_antenna_3_foot_hot_rod_cb_antenna.html
Edited by tx2sturgis
BOO
Ok thanks. I intend to use 2 antennas . One for cb and the other for am/fm.
:canada:
Thanks for the lead on francis, will look into them.:canada:
