Fixer32 Posted June 5, 2014 #1 Posted June 5, 2014 Hello everyone! Don't know if I posted correctly I am a new member. I screwed my drain plug down to far on my 2004 Royal Star Venture float bowl and cracked it anybody know where I can get a used one so I can get back on he road or some other way of plugging the drain. The carb that needs the bowl is the left rear sitting on the bike, it is the one the throttle cables attach to.
RedRider Posted June 5, 2014 #2 Posted June 5, 2014 If someone doesn't have an extra set of parts carbs laying around, you could try Pinwall Cycle. They usually have a large selection of Venture salvage parts. RR
Fixer32 Posted June 5, 2014 Author #3 Posted June 5, 2014 Bought a set of carbs on eBay 150 clams. Thought about JB welding it shut but didn't want to have it leak while riding and turn into the Human Torch. I'm such a retard, I had the plug out and forgot to put it back in tore the carbs off the bike fast ( I was at my shop and wanted to leave & go home) and forgot that the plug does not bottom out and tightened it all the way and cracked the seat. So if anyone takes the drain plug out be very very careful not to go to far in with it when tightening LOOK AT THE OTHER DRAIN PLUGS to see how far they are into the float bowl.
