SARNA66 Posted June 2, 2014 #1 Posted June 2, 2014 annoying bounce, Is my shock shot- or too much air-not enough? Discus, thanks Chris
Ventureless Posted June 2, 2014 #2 Posted June 2, 2014 My stock shock was a piece of crap so I bought a Hagon. I left the settings as it was shipped. I love the ride. Much stiffer. Now after my wife riding a long (for her) 200+ mile day, I have realized that the shock is set perfectly for when both of us are on the bike. I get a bouncy feeling when it is just me and I guess that will continue because it is a pain in the ass to adjust the shock back and forth each time between solo and 2 up. I realize I am talking about a Hagon and I am not sure how that relates to the stock shock. But if set to tight (to much air maybe? Or not enough?) you could get some bounce. Mine feels closer to a hard tail the way it bounces when I am solo. But it handles the twisties like my old sport touring bike.
Freebird Posted June 2, 2014 #3 Posted June 2, 2014 If it is that bouncy, you may have a bad shock. That's what happens when the oil leaks out of them and at that point, all you can do is replace it.
Ace Posted June 2, 2014 #4 Posted June 2, 2014 Sounds like your shock is probably toast, sounds as if there is there is no oil left to dampen the spring. I , like Bumblebee went with a heavy duty Hagon shock and could not be happier, it rides and handles excellent and I can adjust preload and dampening of the shock.
Ventureless Posted June 2, 2014 #5 Posted June 2, 2014 and I can adjust preload and dampening of the shock. Dampening is easy to adjust without removing anything. Preload is a pain to get to. Yes it can be set easily after removing a bunch of things to get to the nut.
Ventureless Posted June 2, 2014 #6 Posted June 2, 2014 Also I guess in my original reply, I was talking about a different kind of bounce. Mine is just due to preload being set to tight for me solo so I am feeling every tiny bump. It is not like a riding in a caddy bounce!
Wizard765 Posted June 2, 2014 #8 Posted June 2, 2014 I see you have a '99. Is it still the original shock? If so...15 years...think you got your moneys worth out of it ! It's funny that we accept this sort of thing... It is very rare to hear of a shock going bad on a 1st gen.. for example my 84 is 30 years old with 140,000 Kms and the shock is original.. It even still holds pressure for the whole summer.. almost never have to adjust it unless I'm taking someone larger than my wife for a ride..
SARNA66 Posted June 2, 2014 Author #9 Posted June 2, 2014 As far as I know, it is original , about 40 lbs. Im tall and 325, luckily the wife is only 125
Ventureless Posted June 2, 2014 #10 Posted June 2, 2014 As far as I know, it is original , about 40 lbs. Im tall and 325, luckily the wife is only 125 Just go ahead and get a Hagon HD or other aftermarket. I am 6'4" 300 + and my wife is around 5'7" and 150. I know we are over the weight limit of the bike but we still ride together. I was scared with the stock shock. With the Hagon, I honestly don't even realize she is back there except when doing parking lot slow manuevers. The bike handles so much better solo or 2 up with the Hagon. And that is even when my stock shock was good.
