I don't know if this might help anyone else who might have the CB:ERR message or not. Mine did this on the weekend. I couldn't control the volume, change the channel or turn it off.
The only thing that had happened recently was that the passenger PTT button had broken and fell off. I think it got hit by a riding boot but I can't prove it. The CB was still working even after I noticed the button was missing. I used some pliers to remove what was left of the threaded brass stud but didn't get around to replacing the button until today. After pushing the button in and out a few times the CB error went away and it seems to be working normally again. I can't explain why this worked but it did.
Kind of reminds me of when Dad use to wack the top of the TV and it would start to work.
Gary
I had that happen once before. I think I pulled the fuse to kill the power for the radio/cb. Then did a power up re-boot type thing. Give it a try. Otherwise, like the old tube tv's use tinfoil on the antenna. Might work as we'll?? :080402gudl_prv:
Gary
Thanks Steve. It's fixed now.
Guess the whack on the side of the radio and the tinfoil on the antenna worked! Actually I found the radio would reset to clear the Err code on the screen.
Tin foil on the antenna? I thought you were supposed to put the tin foil in the helmet.
Mike
Tinfoil is easier to shape to your head then the colander that I use. You have to be very careful whenever you are outdoors. The NSA monitors everything now even your thoughts!
Better to be safe than sorry!!!!!
