Money Venture Posted May 10, 2014 #1 Posted May 10, 2014 I finally got around to bleeding the brakes today. I have rear brakes again. The rear reservoir was empty but it didn't show a leak. It came to me this way. The hose from the reservoir to the rear master looks funky. I don't see a leak but it would be this hose if I had to guess. The bleeder by the steering was really full of air. Fun to ride with brakes all around.
Eck Posted May 10, 2014 #2 Posted May 10, 2014 Keep your eye on the rear caliper for it may be "slowly" leaking around the pistons and the brake dust helps soak it up so that it always looks dry.
Venturous Randy Posted May 10, 2014 #3 Posted May 10, 2014 Also, make sure you do not fill the reservoir too full or when your brakes warm up, they may bind and stop you. Always carry an 8mm wrench with you. RandyA
Yammer Dan Posted May 10, 2014 #4 Posted May 10, 2014 Also, make sure you do not fill the reservoir too full or when your brakes warm up, they may bind and stop you. Always carry an 8mm wrench with you. RandyA :sign yeah that::sign yeah that: For Sure!!!
