I am looking for a speaker & amp system for my 06 Venture. I want something that I can really crank up going down the highway with good quality sound.
Any suggestions???????
Me too
Best speakers I know of that will fit are the Polk Audio DB401s
[ame=http://www.amazon.ca/Polk-Audio-4-Inch-Coaxial-Speakers/dp/B000P0R6GQ]Polk Audio DB401 4-Inch Coaxial Speakers (Pair, Silver): Amazon.ca: Electronics@@AMEPARAM@@http://ecx.images-amazon.com/images/I/41Cgy6jdaAL.@@AMEPARAM@@41Cgy6jdaAL[/ame]
Hopefully someone will come up with an AMP that is small and powerful and will hide somewhere on the bike without sacrificing useful storage space.
The speakers are designed for marine use and as such they are weather resistant AND for a 4" speaker they sound pretty good. With an amp the actually sound VERY good
Bazooka make a set up that plugs right in, if you don't mind spending the money. Here's the lowest priced one I've found so far. Yes, I'm looking too, just can't hear it at highway speeds. Sorry, this one is just the amp and wire kit.
[ame=http://www.amazon.com/Bazooka-MC-YAM-AMK-Yamaha-4-Channel-Amplifier/dp/B001MJ0GZC]Amazon.com: Bazooka MC-YAM-AMK Yamaha 4-Channel Amplifier Kit: Car Electronics@@AMEPARAM@@http://ecx.images-amazon.com/images/I/51c8ToZr0TL.@@AMEPARAM@@51c8ToZr0TL[/ame]:080402gudl_prv:
Why would you not go with a good quality headset as the bike is already wired for it.:confused24: That way you will get better sound quality without anoying everybody else riding around or with you.
:canada:
Edited by Bert2006
Ohio don't have a helmet law so since from his state flag on profile I'm guessing he's from there. Might not wear one all the time. Not looking for debate on the why's or why nots of helmet usage, just making an observation. As for those speakers, I wonder if they make them in bullet style for a RSTD W/O fairing....
:canada:
Because I tried that and HATED the lead hanging off my head. Not for me.
I spent a lot of time and money trying to make the sound system better on my 04 , there just isn't any room for bigger speakers and thats the key, you can have a 1000w amp but with those little speakers its just a loud am radio. No bass . Now with a HD you can have some good tunes , ask me how I know haha.
:canada:
Listen to someone's tunes then hear their pipes trying to shake the screws out of Everyone's bike! :whistling: :backinmyday: :stirthepot:
  • 1 month later...
Go to Crutchfield and check out the Clarion amp I am using.
http://www.crutchfield.com/p_020XC1410/Clarion-XC1410.html
Surprisingly low impact on the electrical system of my 1st Gen. And it isn't much larger than say 2 packs of cigarettes. And very good sound quality for the size and cost.
I have used both the Polk 401's and the 4" Bazookas. Either are OK as far as they can be expected to sound. It takes air movement to create sound, especially bass. The small 4" drivers do fall short a bit. But they sound good. Until and unless you over drive them without a cross over or bass blocker inline. Or tuning down the stereos bass level. So I now have a set of 20 year old Altec Lansing 5 1/2" marine speakers in the fairing where the old stereo and CLASS were.
I have totally removed (and passed on to a member) the entire stock stereo and CB, as well as removing the CLASS in favor of my stereo. I have a Clarion CMS 1 head unit which is pretty good. Navigation of the stored music (thumb drive) could really be easier, but other than that I am quite happy with it. I see that now it is hard to find and has been replaced with the CMS 2.
Buy a Spyder,,,,, problem solved!!! ooppps this is a Venture site,,, sorry about that!
Quit trying to draw us into your web.....
The "Dark Side" is starting to take on a whole new meaning. :doh:
couple of factors to consider
a. can your electrical system provide the additional power for the higher power amp?
b. try to find high power speakers that have high SPL. a speaker with 90db spl powered by a 10watt amp will sound just as loud as a speaker with 80db spl powered by an 80watt amp at the same volume level. Folks incorrectly shop for watts, they should be shoping for speaker spl or the speaker sensitivity rating.
well that is the set up in my bike and works amazing, just because is says 300w dosent means its always drawing it, the amp will draw what it needs and even though it is much less than what a dual speaker system requires it is as small as you can get as a waterproof set up
though on the power end you do need to run a thicker gauge wire to the accessory panel for the deck cause the factory wiring will not take it
  • 4 weeks later...
Are you running any kind of a noise filter with your setup?
  • 2 weeks later...
I ended up going with the amp Black wing linked to and the Kicker speakers. I went with the 2 ohm since the amp is ok with them. Also went with the JBL PRV 175 . Raining right now so can't do a road test, but holy cow does it rock the garage! Also love being able to bluetooth from my phone.
http://i1176.photobucket.com/albums/x337/steve_roseman/Venture/0806141132a.jpg
  • 2 weeks later...
I never tried the PRV without the Clarion amp. I know to hear things well going down the highway you really need to be able to push the speakers. I know there are no heat issues with the PRV when it's feeding the amp. Also no heat issues with the amp. I went with the high side on the amp inputs. I wanted to use the pre-outs from the PRV bit it's only two channel and I may add some rear speakers eventually.
