stickhandle2 Posted May 4, 2014 #1 Posted May 4, 2014 Hi All, Does anyone happen to know what size of wrench is used for the crown nut (I think that is what is called) on the steering head of a 2nd gen when tightening the steering head bearings. Thanks Mike
ragtop69gs Posted May 4, 2014 #2 Posted May 4, 2014 If I remember right, my 1 1/8" combo wrench fit it. Not sure what the metric equivalent is.
MidlifeVenture Posted May 4, 2014 #3 Posted May 4, 2014 http://www.venturerider.org/forum/showthread.php?t=511 Thought it was a screw driver and hammer:big-grin-emoticon:
stickhandle2 Posted May 4, 2014 Author #4 Posted May 4, 2014 http://www.venturerider.org/forum/showthread.php?t=511 Thought it was a screw driver and hammer:big-grin-emoticon: I am talking about the nut at the top, yes you use a screwdriver and a hammer to tighten the bottom 2 nuts. Just looking for the size so I can use a wrench rather then Channel locks or an adjustable wrench. Mike
wrnchjox Posted May 4, 2014 #5 Posted May 4, 2014 I could be mistaken but i believe that nut is 32 mm.
Marcarl Posted May 4, 2014 #7 Posted May 4, 2014 Put a socket on it, and if it won't go on it's too small, so you get a bigger one,,,, now if it goes on and starts to slip look for something a little bit smaller,,, if the next one fits just right,,,,,,,,,,, that's the one I would use!!!! Can't help it,,,, I'm so wise:whistling:
stickhandle2 Posted May 4, 2014 Author #8 Posted May 4, 2014 Put a socket on it, and if it won't go on it's too small, so you get a bigger one,,,, now if it goes on and starts to slip look for something a little bit smaller,,, if the next one fits just right,,,,,,,,,,, that's the one I would use!!!! Can't help it,,,, I'm so wise:whistling: Carl, You are always the deep and insightful one, I should've just axed you first. Thanks
stickhandle2 Posted May 4, 2014 Author #9 Posted May 4, 2014 The proper size is 27mm Perfect thanks Don. Mike
Marcarl Posted May 4, 2014 #10 Posted May 4, 2014 Carl, You are always the deep and insightful one, I should've just axed you first. Thanks Spelling error!!!!!!!!!! 'asked' is not spelled 'axed',,,, or maybe I should run???? Glad I got a 1st gen still.
Sylvester Posted May 4, 2014 #11 Posted May 4, 2014 Just for correct language, it is a Castle Nut. Man that wore me out.
bongobobny Posted May 4, 2014 #12 Posted May 4, 2014 Dingy makes the perfect wrench for the job! I suppose I can lend you mine (KEY WORD LEND) if you want or buy one from him. Eliminates the hammer and screwdriver and allows a torque wrench to be applied. I can give it to groundhugger WED if you like...
stickhandle2 Posted May 4, 2014 Author #13 Posted May 4, 2014 Dingy makes the perfect wrench for the job! I suppose I can lend you mine (KEY WORD LEND) if you want or buy one from him. Eliminates the hammer and screwdriver and allows a torque wrench to be applied. I can give it to groundhugger WED if you like... Hi Bob, Appreciate the offer, but I should be ok with the hammer and screwdriver. But you can let me pick your brain for a few minutes at Carls in a couple weeks, regarding some different roads in your area. Thanks again for the offer. Mike.
Marcarl Posted May 4, 2014 #14 Posted May 4, 2014 Dingy makes the perfect wrench for the job! I suppose I can lend you mine (KEY WORD LEND) if you want or buy one from him. Eliminates the hammer and screwdriver and allows a torque wrench to be applied. I can give it to groundhugger WED if you like... I think Carl has an extra one or two even,,, don't remember how that happened, but I believe it was a brain fart or something, I'll have to ask him sometime.
Mike G in SC Posted May 5, 2014 #15 Posted May 5, 2014 Just for correct language, it is a Castle Nut. Man that wore me out. Maybe,,, this is a Castle Nut,,
Beau-Kat Posted May 5, 2014 #16 Posted May 5, 2014 Just for correct language, it is a Castle Nut. Man that wore me out. I think it is called an ACORN nut. A castle nut looks like a castle on top (like you find on spindles and axles with cotter pins going through them).
