Hi All,
Does anyone happen to know what size of wrench is used for the crown nut (I think that is what is called) on the steering head of a 2nd gen when tightening the steering head bearings.
Thanks
Mike
Put a socket on it, and if it won't go on it's too small, so you get a bigger one,,,, now if it goes on and starts to slip look for something a little bit smaller,,, if the next one fits just right,,,,,,,,,,, that's the one I would use!!!!
Can't help it,,,, I'm so wise:whistling::think:
Carl,
You are always the deep and insightful one, I should've just axed you first.
Thanks
  stickhandle2 said:
Carl,
Thanks
Spelling error!!!!!!!!!! 'asked' is not spelled 'axed',,,, or maybe I should run???? Glad I got a 1st gen still.
Dingy makes the perfect wrench for the job! I suppose I can lend you mine (KEY WORD LEND) if you want or buy one from him. Eliminates the hammer and screwdriver and allows a torque wrench to be applied. I can give it to groundhugger WED if you like...
Hi Bob,
Appreciate the offer, but I should be ok with the hammer and screwdriver. But you can let me pick your brain for a few minutes at Carls in a couple weeks, regarding some different roads in your area.
Thanks again for the offer.
Mike.
I think Carl has an extra one or two even,,, don't remember how that happened, but I believe it was a brain fart or something, I'll have to ask him sometime.
  Sylvester said:
Just for correct language, it is a Castle Nut.
Man that wore me out. :clap2:
:farmer:
I think it is called an ACORN nut.
A castle nut looks like a castle on top (like you find on spindles and axles with cotter pins going through them).
