My tailight on the 06RSV seems to be loose and I cant figure out to get it to be tighter. Is it normal for them to move around a bit? If not, how do I snug it up. All the bolts are secure but the housing moves as if on a thick gasket or something.:confused24:
:canada:
Pretty much normal I recall having the same concern on my 98 TC and I just checked my 07 Venture they are mounted on a rubber gasket, probably helps to minimize vibration that would shorten the bulb life and also keeps water from seeping in.
