Steve S Posted March 8, 2008 #1 Posted March 8, 2008 I'm rebuilding the Black Beast from the accident I had in November. While I have it down I am doing several mods. I will talk about those in another thread and reserve this one for the bar end weights. I wanted to keep the bar end weights to reduce vibration and have a place to rest my hand while I was using the cruise control. Once I got the handle bars stripped down here is what I came up with. The threaded plugs that the weights screw into are welded in with just a spot weld on the bottom side of the bar. I went out to my brother-in-law's shop and ground the weld out. (Since the stock bars were ruined I didn't get real creative about saving them). If you want to save the stock bars it would be easy to grind just the weld, then reweld the plugs back in later. I marked the new bars so I could drill a 3/8" hole in them to weld the plugs back in. Then I had my brother-in-law spot weld the plugs in. Now this is important. DONT PICK THE BAR UP BY THE HANDLE. IT'S HOT!!!!!! (Yeah I know. I knew better. But since the brain surgery in January my short term memory seems to be shot:whistling:.) I now have a set of Flander's bars with the option to use the bar weights or not. All it cost me was 30 minutes of my brother-in-law laughing at me cause I burnt my hand. The things we suffer through to ride:confused24:. I hope this can be of use to someone out there. Ride safe.
pegscraper Posted March 8, 2008 #2 Posted March 8, 2008 If you'd rather not ruin the old handlebars, or if you'd like to use the weights on a bike that never had them - like mine - pick up the correct size metric nuts, grind them round to fit inside the bars, and weld them in place. Then sell the old bars on ebay for a few bucks.
