my fest gen venture decided to take a leak on the drive today lol its never dun that before was leaking out of the elbow on the water pump so i wiggled it a bit and then run the bike no more leak should i be concerned ? has anyone else had this happen ? :detective:
REPLACE IT! They are only some $30 new, and easier to replace now when everything apart rather than later. Also replace the T-stat housing for the same reason.
-Pete, in Tacoma WA USA
Ditto!!
Hey Peder, where are you finding them for $30 new?? Parts Shark?
Working from MEMORY of repair work a couple years ago, I often use Partzilla or Boats.net, but may have found new old stock parts on e-bay. Despite others experience, I've used Partzilla for several years for all my bikes with zero problems, including order cancellations.
