What size are the vacuum lines on my 2nd gen??
They looked cracked-I want to change them out
I could not find the info
Thanks
Chris
I need a windshield about 2 " shorter
any thoughts??
new clutch time also (
Chris,
Check out Skydoc's ad in the classified's here for a clutch or Barnett makes one also.
Shorter windshield? You can cut yours down (you could ask Darrin to help).
I 2nd SKYDOCs upgrade. I have put it on 2 bikes and it works amazing . Plus the help insight from skydoc.
As for the windshield I will be cutting half inch off of mine tomorrow. Love it in the day but hate looking through it at night.
I will be cutting from the bottom to lessen the shaping and sanding needed to look original.
Cutting up half inch and with a dremel relocating the mounting holes and slots.
I have cut a few windshields down before with real crappy results. If I ever eanted to do it again I would go to a pro. There they can cut and reshape
