It seems like when I twist my throttle there is an initial slight stumble, then revs strong.
I have new plugs by NGK replace a couple of vacuum caps that looked cracked.
what else should I be doing?
thanks
Chris
:confused07:
Sarna. Ther eis not much to it but you do need a set of gauges or mercury manotmet and a long philiips and small flathead to complete this. There are other methods that work also but simpler and easier with the right tools. If you don't have a manometer of some kind I suggest finding someone here that doesn't live to far and buying them breakfast for a synch.
https://www.youtube.com/watch?v=XGkoFKe8Y5w
I was trying to upload video showing where the synch screws are but it didn't show up well.
Thee is one screw phillps head on the right side then one on the left but you can only reach it from the right
The one on the right changes the relation between right front and rear and left screw balances left front and rear.
On the left side is a flat head screw that balances left side bank to right side bank. Ill try to take some HD pictures at night and maybe the flash will show the screws better
Nope!! When most guys on here start getting old you find them getting 2nd Gens!!! Older and slower...:whistling: I was just trying to convince the warden I had slowed down!!!:innocent:
