mralex714 Posted April 12, 2014 #1 Posted April 12, 2014 My shock dampener knob will not turn. Is there a fix or is it done?
Marcarl Posted April 12, 2014 #2 Posted April 12, 2014 It goes from 1 to 4 and then back again, doesn't go from 4 to 1,,, sooo, 1,2,3,4 and then 4,3,2,1. Does that help?
mralex714 Posted April 12, 2014 Author #3 Posted April 12, 2014 It goes from 1 to 4 and then back again, doesn't go from 4 to 1,,, sooo, 1,2,3,4 and then 4,3,2,1. Does that help? Doesn't move in either direction.
MiCarl Posted April 12, 2014 #4 Posted April 12, 2014 There is a cable from the knob to the shock. The cable should have some give to it. If it's locked up tight it's probably stuck at the knob.
